Part Number: TLV627432
Other Parts Discussed in Thread: TPS62743,
Customer need a P2P replacement of TPS62743 due to supply issue, They want to if could use TLV627432 to replace TPS62743 without any design change.
I just check the datasheet and found this two has the same pin out, the typical circuit is same. so, would you please help to confirm if there are any difference of these two. thanks.
https://www.ti.com.cn/cn/lit/ds/symlink/tlv627432.pdf
https://www.ti.com.cn/cn/lit/ds/symlink/tps62743.pdf
