Part Number: TPS2121
Hi Team,
Does we have solution which can support larger continue current solution like TPS2121 ?
Customer need a 19V/20V switch, up to 5A.
Thanks!
Hi Kai,
At this time, we only offer TPS212x devices that are capable of handling 20V. Among those, the TPS2121 is the highest current integrated powerMUX in the portfolio.
For your application, a non-integrated solution could be used due to your higher current requirements. More information on that can be found in our “Power Multiplexing Using Load Switches and eFuses” application report located at:
https://www.ti.com/lit/an/slva811a/slva811a.pdf
Elizabeth
