LMR70503: Using an external VREF
Part Number: LMR70503
For an OLED design I need to generate a negative voltage to control the luminance. As the luminance is depending on the temperature, I need to adapt this negative voltage on fly.
I plan to use the LMR70503 to generate the negative voltage and I'm playing on the VREF (not using the internal VRef) to adapt the output voltage. The Vref is generated by a follower from a PWM signal.
Do you think that the LMR can work like this ?
Thanks for your help.
