Hi team,
My customer wants to design for Super Cap charger
Vin=5V@2A(max) VO=14.4V Io=0.7A(or less 0.7A). due to Iin limitation.
Does TI have a suitable solution for this spec? or any discrete circuit to achieve the design? thanks!
Hi Jimmy,
TI does not have a single IC standalone, boosting super-cap charger solution. The BQ25792 buck-boost charger would work but requires host control and has trickle and pre-charge which until the cap voltage is high enough, which extends charge time. If your super cap does not require trickle/pre charge (most do not) and since your charge current seems flexible, I recommend using a boost converter running in current limit. I have move this post to the boost converter team.
Jeff
