Other Parts Discussed in Thread: TPS22954, TPS22953
I am looking for a part similar to the TPS22810 but with its ENABLE activation / deactivation at each rising edge using a momentary switch on the front panel.
This alternative circuit should also have a second enable pin acting as a master reset also with a rising edge property.
My end goal is to kill the device with the uC without using the front panel switch.
Anything in mind ?
