Part Number: LM7480-Q1
Other Parts Discussed in Thread: LM74800-Q1
I am designing a power supply with battery charge and discharge functions. I need to cancel reverse current protection of LM7480-Q1 thus allowing bi-directional current flow., and still maintaining on/off control and reverse battery voltage protection.
Can you confirm if using the part LM74801-Q1 instead of LM74800-Q1 + leaving the "C" pin floating + using common drain configuration works for my project.
Best Regards
