TPS7A7200: TPS7A7200RGTT pin equivalent substitute
Part Number: TPS7A7200
since the TPS7A7200RGTT is out of stock, are there any other LDOs that have compatible pinout with similar specs which have stock available?
Thank you!
Alberto
  • Hi Alberto,
    Unfortunately this family of parts has been very popular and we do not have any other p2p parts. However, the closest we have is the TPS7A8400ARGRR which is the next gen version of this device which uses a very similar pinout (slightly larger) and would require less alterations to the layout if that is an option. During these challenging times to get certain ICs we're seeing some customers are willing to go this route. Below is a quick spec comparison of the two parts.
  • Hi Kyle,
    thank you for the quick response!
    I will let you know if I have anything else.
    Alberto
