Hi team,
I got a question from customer.
I use TL494 to make a 12-16.8v input, 110V / 100W / 60Hz output correction wave inverter. The test found that the output voltage difference between no-load and load is about 10V.
Attached is my schematic diagram, please have a look, is there any parameter need to be adjusted?
Thank you very much for your help.
