Hi
Customers use TPS61050 to control Flash LED in PC CAMERA, the circuit is as follows.
LED_VCC supply voltage is 5V SDA, SCL, Flash_SYNC signal voltage is 1.8V When the power is found to be off, the LED will flash once.
When the LED_VCC voltage is reduced to 3.3V. Power is off, the LED will not flash.
When the current application to customers LED_VCC supply voltage of 5V. What are ways to avoid the power Power off, LED will not flash it?
