TPS659037: TPS6590378 and AM5728: SMPS1/2 output is changing on I2C access timing
Guru 19645 points
Part Number: TPS659037
Other Parts Discussed in Thread: AM5728
On the startup timing, when I2C access on several times by system side (AM5728), SMPS1 and SMPS2 output (AM5728 VDD_MPU input) voltage are changed at all such times.
 (ex. 1.2V1.09V1.06V→ 1.2V→1.09V1.06V…)
Is these voltage changing are assumed normal operation?
If abnormal operation, please let me know any idea for measure.
・Waveform; Blue is I2C signal and access timing, Yellow is SMPS1/2 (VDD_MPU)
・TPS6590378 schematic; red point is measured point.
・This question is accompanied by below processor thread. we hope advice from the viewpoints of the PMIC side, too.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1012960/am5728-voltage-change-of-vdd_mpu-at-start-up/3754986
Satoshi
