The data sheet of LM27762 explains that if you do not use the PGOOD function, connect it to the ground, but since the PGOOD terminal is an open drain, I think that you can open it without connecting it to the ground.
I don't understand why the datasheet says connect to ground.
Shouldn't I use this terminal without connecting it anywhere?
