Hi team,
Could you give me comment on following customer question?
Q1. What is the role of the D2 (85V) at Figure 10-25 in the datasheet? Is it always required?
Q2. Could you tell me how to select D2?
Takeshi Sasaki
Hi team,
Takeshi Sasaki
Hi Takeshi,
The purpose of D2 is to supply voltage to the VS pin from A pin. The 10 kohms in series with VS pin (which is placed to limit the current into Zener) limits the current required by the charge pump during startup conditions. So, a diode from A to VS provides uninterrupted current into the VS pin.
