Hello, Under Typical Application in the datasheet a 10ohm resistor is placed in series with Vin but is not described elsewhere in the datasheet. This is also done on the TI eval boards. Is this resistor necessary, like the diode, if not using BIAS input? What is the purpose of this resistor?
Thank you
