TLV766-Q1: Alternative component is needed in order to avoid layout change.
Part Number: TLV766-Q1
Hi, I have a design where TLV76601QWDRBRQ1 is used. Now the PCB manufacturer is telling us that this IC is not available. I have tried to find an alternative with the same package and pin distribution with the same or similar specs but it is being a little hard.
Could you help me? Could you propose an alternative?
Thanks in advance.
  • Hello Iñigo,
    The first option is TLV767-Q1. This is a P2P with same functionality. However, as of now, the TI store only has fixed versions, the adjustable version is currently out of stock.
    In order to find another part that might work for the customer we would need to know the Vin range, expected Vout, and Iout to try and find a good match.
    Edgar Acosta
