I don't understand SRN, SRP.
My design was correct?
I was confused about that...
give me some answer for me
thank you
thank you
Hi Eunsung,
SRP and SRN are analog input pins connected to the internal coulomb-counter peripheral for integrating a small voltage. The gauge will monitor the charge and discharge activity by measuring the voltage across the sense resistor and convert it to a current. By integrating charge passing through the battery, the cell’s SOC is adjusted during battery charge or discharge.
You're schematic looks OK but I recommend you connect SRN to Pack- instead of directly to ground.
Jessica
