BQ77PL900EVM-001: Question about the cell configuration
Part Number: BQ77PL900EVM-001
I'm trying to make my own BMS (with a BQ77PL900) based on the EVM schematic.
Is it inevitable to have the configuration pins "outside", I mean in an hardware way ? Or is there another way to configure the amount of cells with the serial communication, in a software way ?
I want to be allow to change the cell configuration of the BMS and prevent somebody else to modify it by outside.
Thanks in advance for your recommendations.
Evan
  • Hi Evan,
    The configuration pins are on the BQ77PL900 package, it does not have a method to set the configuration by register.  You could use a serial to parallel converter IC, but the pins would still be accessible on the package on the PCB.
