Other Parts Discussed in Thread: UCC28742
Customer is looking for p2p compatible with UCC28740/28742 from competitions. Could you help on this against supply constrain!
Hello Brian,
Can you clarify your question, please?
It sounds like you are asking TI to recommend parts from our competitors that are pin-to-pin compatible with our devices.
I don't think we can do that.
Ulrich
Ulrich, we're promoting our Flyback part in customer side. But if our flyback has no p2p compatible, customer won't consider to use it.
As you know the supply constrain issue is happening for every suppliers, the p2p compatible is one of the policy to consider to design-IN in the customer side. pls be informed. thanks.
Hello Brian,
An extensive web-search did not result in finding any competitor devices which are pin-to-pin compatible with either the UCC28740 or the UCC28742. The customer may reconsider a single source if he cannot procure what he needs from two sources anywhere else.
Ulrich
