TPS2521: Stencil pattern
Genius 17355 points
Part Number: TPS2521
My customer is asking me a question for stencil design of TPS2521 that is described on P45 of the datasheet(SLVSFX8).
It says that “BASED on 0.100 mm THICK STENCIL”.
But they usually uses 0.130mm thick stencil.
Is it no problem to use this example with 0.130mm thick?
Do you have the pattern for 0.130mm thick?
Oba
