Product recommendation
Hi team
Now my customer has a demand: Their MCU has a power supply pin. They need to control this pin to be grounded or connected to the power supply by switching it freely, that is to say, when using a certain function, it needs to be connected to a 1.8V (200mA) power supply. When not in use, it needs to be grounded.
According to this requirement, I hope you can help recommend a device that meets this logic, which also needs to be automotive grade.
  • Hello Zirui,
    A load switch with quick output discharge could work well for your customers needs:
    Our price efficient solution: TPS22919
    Our lowest Ron solution: TPS22971
    If you take a look at the load switch product folder you can find other load switches with additional protection features that may be a benefit for your customer.
