I am currently using the tps7a3001 and tps7a4901 voltage regulator LDO's. According to the datasheets, I can either leave the powerpad open, or tie it to ground. I am prototyping the circuit using a standard breakout board, and because of this I will not have easy access to a ground plane.
Is it okay to leave the pad floating? I will be running voltages in the +5V and regulating it down to +3.3V and -3.3V (post inverter). Previous posts by TI employees have indicated that this can cause "flaky performance".
Alex
