Other Parts Discussed in Thread: TPS568230, TPS51396,
Dear Sir or Madam,
May I know what is voltage range setting for ECO & OOA mode for TPS51396RJER ?
(If I am not able to follow the resistor value given in the datasheet)
Customer might use back TPS568230 when the stock is available.
Since both TPS568230 & TPS51396RJER are pin to pin compatible,
customer want to fix the mode resistors value to cater for both chipsets.
Thanks.
