BQ79606EVM-897: CB is running a short time only when "Enable Cell Balance Comparator"
Part Number: BQ79606EVM-897
Hi Team,
We are trying to follow software development guide to evaluate cell balance function on bq79606-Q1EVM.
Attached is our register settings. We are confused when click "Enable Cell Balance Comparator", CB status is shown as complete immediately.
Cell voltage is ~ 4.2 volts and CB_DONE_THRESH is set to 2.8 volts. Supposedly CB should keep running when cell voltage reach 2.8 volts.
Do we have standard process how to utilize CB_DONE_THRESH to activate balancing function? Kindly point out which settings or process is wrong.
# bq79606-Q1 Register Exports File
# File creation date: 2021.07.22 at 14:00:31 TST
# File Format: Register address in hex(tab)Register value in hex(tab). Addtional characters in line ignored for import.
# All values are hex not prefixed with 0x and not case sensitive for import.
0	00	DEVADD_OTP Description: Device Address OTP Default)
1	01	CONFIG Description: Device Configuration)
2	00	GPIO_FLT_MSK Description: GPIO Fault Mask)
3	00	UV_FLT_MSK Description: UV Comparator Fault Mask)
4	00	OV_FLT_MSK Description: OV Comparator Fault Mask)
5	00	UT_FLT_MSK Description: UT Comparator Fault Mask)
6	00	OT_FLT_MSK Description: OT Comparator Fault Status Mask)
7	00	TONE_FLT_MSK Description: FAULT_ Bus Tone Fault Mask)
8	00	COMM_UART_FLT_MSK Description: UART Fault Mask)
9	00	COMM_UART_RC_FLT_MSK Description: UART Receive Command Fault Mask)
A	00	COMM_UART_RR_FLT_MSK Description: UART Receive Response Fault Mask)
B	04	COMM_UART_TR_FLT_MSK Description: UART Transmit Fault Mask)
C	00	COMM_COMH_FLT_MSK Description: COMH Bus Fault Mask)
D	00	COMM_COMH_RC_FLT_MSK Description: COMH Receive Command Fault Mask)
E	00	COMM_COMH_RR_FLT_MSK Description: COMH Receive Response Fault Mask)
F	00	COMM_COMH_TR_FLT_MSK Description: COMH Transmit Fault Mask)
10	00	COMM_COML_FLT_MSK Description: COML Bus Fault Mask)
11	00	COMM_COML_RC_FLT_MSK Description: COML Receive Command Fault Mask)
12	00	COMM_COML_RR_FLT_MSK Description: COML Receive Response Fault Mask)
13	00	COMM_COML_TR_FLT_MSK Description: COML Transmit Fault Mask)
14	00	OTP_FLT_MSK Description: OTP Page Fault Mask)
15	00	RAIL_FLT_MSK Description: Power Rail Fault Mask)
16	00	SYS_FLT1_FLT_MSK Description: System Fault  1 Mask)
17	00	SYS_FLT2_FLT_MSK Description: System Fault  2 Mask)
18	00	SYS_FLT3_FLT_MSK Description: IC System Fault 3 Mask)
19	00	OVUV_BIST_FLT_MSK Description: OVUV BIST Fault Mask)
1A	00	OTUT_BIST_FLT_MSK Description: OTUT BIST Fault Mask)
1B	00	SPARE_01 Description: Spare Register)
1C	00	SPARE_02 Description: Spare Register)
1D	00	SPARE_03 Description: Spare Register)
1E	00	SPARE_04 Description: Spare Register)
1F	00	SPARE_05 Description: Spare Register)
20	3C	COMM_CTRL Description: Communication Control)
21	3C	DAISY_CHAIN_CTRL Description: Daisy Chain RX/TX Enable Control)
22	00	TX_HOLD_OFF Description: Transmitter Holdoff Control)
23	00	COMM_TO Description: Communication Timeout Control)
24	62	CELL_ADC_CONF1 Description: Cell ADC Configuration 1)
25	08	CELL_ADC_CONF2 Description: Cell ADC Configuration 2)
26	0C	AUX_ADC_CONF Description: Auxiliary ADC Configuration)
27	00	ADC_DELAY Description: ADC Configuration)
28	00	GPIO_ADC_CONF Description: GPIO ADC Result Configuration)
29	00	OVUV_CTRL Description: Cell Hardware Protection Channel Control)
2A	32	UV_THRESH Description: Comparator Under Voltage Threshold)
2B	64	OV_THRESH Description: Comparator Over Voltage Threshold)
2C	00	OTUT_CTRL Description: GPIO Over and Under Temperature Comparator Control)
2D	5A	OTUT_THRESH Description: Comparator Over Temperature Threshold)
2E	0A	COMP_DG Description: Hardware Protection Deglitch)
2F	30	GPIO1_CONF Description: GPIO1 Configuration)
30	30	GPIO2_CONF Description: GPIO2 Configuration)
31	30	GPIO3_CONF Description: GPIO3 Configuration)
32	30	GPIO4_CONF Description: GPIO4 Configuration)
33	30	GPIO5_CONF Description: GPIO5 Configuration)
34	30	GPIO6_CONF Description: GPIO6 Configuration)
35	00	CELL1_GAIN Description: Cell 1 Gain Calibration)
36	00	CELL2_GAIN Description: Cell 2 Gain Calibration)
37	00	CELL3_GAIN Description: Cell 3 Gain Calibration)
38	00	CELL4_GAIN Description: Cell 4 Gain Calibration)
39	00	CELL5_GAIN Description: Cell 5 Gain Calibration)
3A	00	CELL6_GAIN Description: Cell 6 Gain Calibration)
3B	00	CELL1_OFF Description: Cell 1 Offset Calibration)
3C	00	CELL2_OFF Description: Cell 2 Offset Calibration)
3D	00	CELL3_OFF Description: Cell 3 Offset Calibration)
3E	00	CELL4_OFF Description: Cell 4 Offset Calibration)
3F	00	CELL5_OFF Description: Cell 5 Offset Calibration)
40	00	CELL6_OFF Description: Cell 6 Offset Calibration)
41	00	GPIO1_GAIN Description: GPIO1 Gain Calibration)
42	00	GPIO2_GAIN Description: GPIO2 Gain Calibration)
43	00	GPIO3_GAIN Description: GPIO3 Gain Calibration)
44	00	GPIO4_GAIN Description: GPIO4 Gain Calibration)
45	00	GPIO5_GAIN Description: GPIO5 Gain Calibration)
46	00	GPIO6_GAIN Description: GPIO6 Gain Calibration)
47	00	GPIO1_OFF Description: GPIO1 Offset Calibration)
48	00	GPIO2_OFF Description: GPIO2 Offset Calibration)
49	00	GPIO3_OFF Description: GPIO3 Offset Calibration)
4A	00	GPIO4_OFF Description: GPIO4 Offset Calibration)
4B	00	GPIO5_OFF Description: GPIO5 Offset Calibration)
4C	00	GPIO6_OFF Description: GPIO6 Offset Calibration)
4D	00	GPAUXCELL_GAIN Description: "GP ADC Offset, CH1")
4E	00	GPAUXCELL_OFF Description: "GP ADC Offset, CH1")
4F	00	GPAUX_GAIN Description: "GP ADC Offset, CH2-32")
50	00	GPAUX_OFF Description: "GP ADC Offset, CH2-32")
51	F2	VC1COEFF1 Description: Cell 1 ADC Gain Correction)
52	7E	VC1COEFF2 Description: Cell 1 ADC Gain Correction)
53	F1	VC1COEFF3 Description: Cell 1 ADC Gain Correction)
54	5F	VC1COEFF4 Description: Cell 1 ADC Gain Correction)
55	F1	VC1COEFF5 Description: Cell 1 ADC Gain Correction)
56	07	VC1COEFF6 Description: Cell 1 ADC Gain Correction)
57	00	VC1COEFF7 Description: Cell 1 ADC Gain Correction)
58	00	VC1COEFF8 Description: Cell 1 ADC Gain Correction)
59	10	VC1COEFF9 Description: Cell 1 ADC Offset/ Gain Correction)
5A	F3	VC1COEFF10 Description: Cell 1 ADC Offset Correction)
5B	CB	VC1COEFF11 Description: Cell 1 ADC Offset Correction)
5C	09	VC1COEFF12 Description: Cell 1 ADC Offset Correction)
5D	E0	VC1COEFF13 Description: Cell 1 ADC Offset Correction)
5E	03	VC1COEFF14 Description: Cell 1 ADC Offset Correction)
5F	7B	VC2COEFF1 Description: Cell 2 ADC Gain Correction)
60	00	VC2COEFF2 Description: Cell 2 ADC Gain Correction)
61	EA	VC2COEFF3 Description: Cell 2 ADC Gain Correction)
62	7F	VC2COEFF4 Description: Cell 2 ADC Gain Correction)
63	F0	VC2COEFF5 Description: Cell 2 ADC Gain Correction)
64	07	VC2COEFF6 Description: Cell 2 ADC Gain Correction)
65	00	VC2COEFF7 Description: Cell 2 ADC Gain Correction)
66	00	VC2COEFF8 Description: Cell 2 ADC Gain Correction)
67	C0	VC2COEFF9 Description: Cell 2 ADC Offset/ Gain Correction)
68	F4	VC2COEFF10 Description: Cell 2 ADC Offset Correction)
69	A7	VC2COEFF11 Description: Cell 2 ADC Offset Correction)
6A	45	VC2COEFF12 Description: Cell 2 ADC Offset Correction)
6B	F4	VC2COEFF13 Description: Cell 2 ADC Offset Correction)
6C	03	VC2COEFF14 Description: Cell 2 ADC Offset Correction)
6D	99	VC3COEFF1 Description: Cell 3 ADC Gain Correction)
6E	00	VC3COEFF2 Description: Cell 3 ADC Gain Correction)
6F	01	VC3COEFF3 Description: Cell 3 ADC Gain Correction)
70	60	VC3COEFF4 Description: Cell 3 ADC Gain Correction)
71	EE	VC3COEFF5 Description: Cell 3 ADC Gain Correction)
72	07	VC3COEFF6 Description: Cell 3 ADC Gain Correction)
73	00	VC3COEFF7 Description: Cell 3 ADC Gain Correction)
74	00	VC3COEFF8 Description: Cell 3 ADC Gain Correction)
75	00	VC3COEFF9 Description: Cell 3 ADC Offset/ Gain Correction)
76	EF	VC3COEFF10 Description: Cell 3 ADC Offset Correction)
77	03	VC3COEFF11 Description: Cell 3 ADC Offset Correction)
78	C6	VC3COEFF12 Description: Cell 3 ADC Offset Correction)
79	F1	VC3COEFF13 Description: Cell 3 ADC Offset Correction)
7A	03	VC3COEFF14 Description: Cell 3 ADC Offset Correction)
7B	D3	VC4COEFF1 Description: Cell 4 ADC Gain Correction)
7C	7F	VC4COEFF2 Description: Cell 4 ADC Gain Correction)
7D	EC	VC4COEFF3 Description: Cell 4 ADC Gain Correction)
7E	1F	VC4COEFF4 Description: Cell 4 ADC Gain Correction)
7F	F1	VC4COEFF5 Description: Cell 4 ADC Gain Correction)
80	07	VC4COEFF6 Description: Cell 4 ADC Gain Correction)
81	00	VC4COEFF7 Description: Cell 4 ADC Gain Correction)
82	00	VC4COEFF8 Description: Cell 4 ADC Gain Correction)
83	D0	VC4COEFF9 Description: Cell 4 ADC Offset/ Gain Correction)
84	FE	VC4COEFF10 Description: Cell 4 ADC Offset Correction)
85	4F	VC4COEFF11 Description: Cell 4 ADC Offset Correction)
86	85	VC4COEFF12 Description: Cell 4 ADC Offset Correction)
87	F6	VC4COEFF13 Description: Cell 4 ADC Offset Correction)
88	03	VC4COEFF14 Description: Cell 4 ADC Offset Correction)
89	91	VC5COEFF1 Description: Cell 5 ADC Gain Correction)
8A	00	VC5COEFF2 Description: Cell 5 ADC Gain Correction)
8B	F1	VC5COEFF3 Description: Cell 5 ADC Gain Correction)
8C	5F	VC5COEFF4 Description: Cell 5 ADC Gain Correction)
8D	EF	VC5COEFF5 Description: Cell 5 ADC Gain Correction)
8E	07	VC5COEFF6 Description: Cell 5 ADC Gain Correction)
8F	00	VC5COEFF7 Description: Cell 5 ADC Gain Correction)
90	00	VC5COEFF8 Description: Cell 5 ADC Gain Correction)
91	50	VC5COEFF9 Description: Cell 5 ADC Offset/ Gain Correction)
92	F8	VC5COEFF10 Description: Cell 5 ADC Offset Correction)
93	47	VC5COEFF11 Description: Cell 5 ADC Offset Correction)
94	44	VC5COEFF12 Description: Cell 5 ADC Offset Correction)
95	02	VC5COEFF13 Description: Cell 5 ADC Offset Correction)
96	00	VC5COEFF14 Description: Cell 5 ADC Offset Correction)
97	F5	VC6COEFF1 Description: Cell 6 ADC Gain Correction)
98	7F	VC6COEFF2 Description: Cell 6 ADC Gain Correction)
99	F5	VC6COEFF3 Description: Cell 6 ADC Gain Correction)
9A	3F	VC6COEFF4 Description: Cell 6 ADC Gain Correction)
9B	ED	VC6COEFF5 Description: Cell 6 ADC Gain Correction)
9C	07	VC6COEFF6 Description: Cell 6 ADC Gain Correction)
9D	00	VC6COEFF7 Description: Cell 6 ADC Gain Correction)
9E	00	VC6COEFF8 Description: Cell 6 ADC Gain Correction)
9F	20	VC6COEFF9 Description: Cell 6 ADC Offset/ Gain Correction)
A0	F9	VC6COEFF10 Description: Cell 6 ADC Offset Correction)
A1	7F	VC6COEFF11 Description: Cell 6 ADC Offset Correction)
A2	43	VC6COEFF12 Description: Cell 6 ADC Offset Correction)
A3	FF	VC6COEFF13 Description: Cell 6 ADC Offset Correction)
A4	03	VC6COEFF14 Description: Cell 6 ADC Offset Correction)
A5	7E	VAUXCOEFF1 Description: GP  ADC Gain Correction - CH2-32)
A6	7F	VAUXCOEFF2 Description: GP  ADC Gain Correction - CH2-32)
A7	DF	VAUXCOEFF3 Description: GP  ADC Gain Correction - CH2-32)
A8	9F	VAUXCOEFF4 Description: GP  ADC Gain Correction - CH2-32)
A9	F3	VAUXCOEFF5 Description: GP  ADC Gain Correction - CH2-32)
AA	07	VAUXCOEFF6 Description: GP  ADC Gain Correction - CH2-32)
AB	00	VAUXCOEFF7 Description: GP  ADC Gain Correction - CH2-32)
AC	00	VAUXCOEFF8 Description: GP  ADC Gain Correction - CH2-32)
AD	90	VAUXCOEFF9 Description: GP  ADC Offset Correction - CH2-32)
AE	E8	VAUXCOEFF10 Description: GP  ADC Offset Correction - CH2-32)
AF	2F	VAUXCOEFF11 Description: GP  ADC Offset Correction - CH2-32)
B0	86	VAUXCOEFF12 Description: GP  ADC Offset Correction - CH2-32)
B1	EE	VAUXCOEFF13 Description: GP  ADC Offset Correction - CH2-32)
B2	03	VAUXCOEFF14 Description: GP ADC Offset Correction)
B3	7F	VAUXCELLCOEFF1 Description: GP  ADC Gain Correction - CH1)
B4	7F	VAUXCELLCOEFF2 Description: GP  ADC Gain Correction - CH1)
B5	D6	VAUXCELLCOEFF3 Description: GP  ADC Gain Correction - CH1)
B6	BF	VAUXCELLCOEFF4 Description: GP  ADC Gain Correction - CH1)
B7	F0	VAUXCELLCOEFF5 Description: GP  ADC Gain Correction - CH1)
B8	07	VAUXCELLCOEFF6 Description: GP  ADC Gain Correction - CH1)
B9	00	VAUXCELLCOEFF7 Description: GP  ADC Gain Correction - CH1)
BA	00	VAUXCELLCOEFF8 Description: GP  ADC Gain Correction - CH1)
BB	90	VAUXCELLCOEFF9 Description: GP  ADC Offset/ Gain Correction  - CH1)
BC	E4	VAUXCELLCOEFF10 Description: GP  ADC Offset Correction  - CH1)
BD	33	VAUXCELLCOEFF11 Description: GP  ADC Offset Correction  - CH1)
BE	84	VAUXCELLCOEFF12 Description: GP  ADC Offset Correction  - CH1)
BF	FB	VAUXCELLCOEFF13 Description: GP  ADC Offset Correction  - CH1)
C0	03	VAUXCELLCOEFF14 Description: GP ADC Offset Correction  - CH1)
C1	02	SPARE_6 Description: Spare Register)
C2	00	CUST_MISC1 Description: Customer OTP Memory 1)
C3	00	CUST_MISC2 Description: Customer OTP Memory 2)
C4	00	CUST_MISC3 Description: Customer OTP Memory 3)
C5	00	CUST_MISC4 Description: Customer OTP Memory 4)
C6	D2	CUST_CRCH Description: Customer CRC High Byte)
C7	5A	CUST_CRCL Description: Customer CRC Low Byte)
100	00	OTP_PROG_UNLOCK1A Description: OTP Program Unlock Code 1A)
101	00	OTP_PROG_UNLOCK1B Description: OTP Program Unlock Code 1B)
102	00	OTP_PROG_UNLOCK1C Description: OTP Program Unlock Code 1C)
103	00	OTP_PROG_UNLOCK1D Description: OTP Program Unlock Code 1D)
104	00	DEVADD_USR Description: Programmable Device Address)
105	00	CONTROL1 Description: Device Control)
106	00	CONTROL2 Description: Function Enable Control)
107	00	OTP_PROG_CTRL Description: OTP Programming Control)
108	00	GPIO_OUT Description: GPIO Output Control)
109	00	CELL_ADC_CTRL Description: Cell ADC Control)
10A	00	AUX_ADC_CTRL1 Description: Auxiliary ADC Control 1)
10B	00	AUX_ADC_CTRL2 Description: Auxiliary ADC Control 3)
10C	00	AUX_ADC_CTRL3 Description: Auxiliary ADC Control 4)
10D	1A	CB_CONFIG Description: Balance Timer Configuration)
10E	01	CB_CELL1_CTRL Description: Cell 1 Balance Timer Configuration)
10F	01	CB_CELL2_CTRL Description: Cell 2 Balance Timer Configuration)
110	01	CB_CELL3_CTRL Description: Cell 3 Balance Timer Configuration)
111	00	CB_CELL4_CTRL Description: Cell 4 Balance Timer Configuration)
112	00	CB_CELL5_CTRL Description: Cell 5 Balance Timer Configuration)
113	00	CB_CELL6_CTRL Description: Cell 6 Balance Timer Configuration)
114	40	CB_DONE_THRESH Description: Cell Balance Done Comparator Threshold)
115	00	CB_SW_EN Description: Cell Balancing Manual Switch Enable)
116	00	DIAG_CTRL1 Description: Diagnostic Control Register 1)
117	00	DIAG_CTRL2 Description: Diagnostic Control Register 2)
118	00	DIAG_CTRL3 Description: Diagnostic Control Register 3)
119	00	DIAG_CTRL4 Description: Diagnostic Control Register 4)
11A	00	VC_CS_CTRL Description: VC Current Source/Sink Control)
11B	00	CB_CS_CTRL Description: CB Current Source/Sink Control)
11C	00	CBVC_COMP_CTRL Description: CB Switch Comparator Control)
11D	00	ECC_TEST Description: ECC Test)
11E	00	ECC_DATAIN0 Description: 1st Data In Byte for Manual ECC Test)
11F	00	ECC_DATAIN1 Description: 2nd Data In Byte for Manual ECC Test)
120	00	ECC_DATAIN2 Description: 3rd Data In Byte for Manual ECC Test)
121	00	ECC_DATAIN3 Description: 4th Data In Byte for Manual ECC Test)
122	00	ECC_DATAIN4 Description: 5th Data In Byte for Manual ECC Test)
123	00	ECC_DATAIN5 Description: 6th Data In Byte for Manual ECC Test)
124	00	ECC_DATAIN6 Description: 7th Data In Byte for Manual ECC Test)
125	00	ECC_DATAIN7 Description: 8th Data In Byte for Manual ECC Test)
126	00	ECC_DATAIN8 Description: 9th Data In Byte for Manual ECC Test)
127	00	GPIO_FLT_RST Description: GPIO Fault Reset)
128	00	UV_FLT_RST Description: UV Comparator Fault Reset)
129	00	OV_FLT_RST Description: OV Comparator Fault Status Reset)
12A	00	UT_FLT_RST Description: UT Comparator Fault Status)
12B	00	OT_FLT_RST Description: OT Comparator Fault Status)
12C	00	TONE_FLT_RST Description: FAULT_ Bus Status Reset)
12D	00	COMM_UART_FLT_RST Description: UART Fault Status Reset)
12E	00	COMM_UART_RC_FLT_RST Description: UART Receive Command Fault Reset)
12F	00	COMM_UART_RR_FLT_RST Description: UART Receive Response Fault Reset)
130	00	COMM_UART_TR_FLT_RST Description: UART Transmit Fault Reset)
131	00	COMM_COMH_FLT_RST Description: COMH Bus Fault Reset)
132	00	COMM_COMH_RC_FLT_RST Description: COMH Receive Command Fault Reset)
133	00	COMM_COMH_RR_FLT_RST Description: COMH Receive Response Fault Reset)
134	00	COMM_COMH_TR_FLT_RST Description: COMH Transmit Fault Reset)
135	00	COMM_COML_FLT_RST Description: COML Bus Fault Reset)
136	00	COMM_COML_RC_FLT_RST Description: COML Receive Command Fault Reset)
137	00	COMM_COML_RR_FLT_RST Description: COML Receive Response Fault Reset)
138	00	COMM_COML_TR_FLT_RST Description: COML Transmit Fault Reset)
139	00	OTP_FLT_RST Description: OTP Page Fault Reset)
13A	00	RAIL_FLT_RST Description: Power Rail Fault Reset)
13B	00	SYS_FLT1_RST Description: System Fault  1 Reset)
13C	00	SYS_FLT2_RST Description: System Fault  2 Reset)
13D	00	SYS_FLT3_RST Description: IC System Fault 3 Reset)
13E	00	OVUV_BIST_FLT_RST Description: OVUV BIST Reset)
13F	00	OTUT_BIST_FLT_RST Description: OTUT BIST Reset)
150	00	OTP_PROG_UNLOCK2A Description: OTP Program Unlock Code 2A)
151	00	OTP_PROG_UNLOCK2B Description: OTP Program Unlock Code 2B)
152	00	OTP_PROG_UNLOCK2C Description: OTP Program Unlock Code 2C)
153	00	OTP_PROG_UNLOCK2D Description: OTP Program Unlock Code 2D)
154	10	SPI_CFG Description: SPI Master Configuration)
155	00	SPI_TX Description: SPI Byte to Transmit)
156	00	SPI_EXE Description: SPI Command Execute)
200	04	PARTID Description: Customer Revision Information)
201	01	SYS_FAULT1 Description: System Fault  1 Status)
202	01	SYS_FAULT2 Description: System Fault  2 Status)
203	00	SYS_FAULT3 Description: IC System Fault 3 Status)
204	C0	DEV_STAT Description: Device Status)
205	00	LOOP_STAT Description: Round Robin Status)
206	18	FAULT_SUMMARY Description: Fault Summary)
207	80	VCELL1_HF Description: Cell 1 Voltage High Byte(Low Pass Filtered))
208	00	VCELL1_LF Description: Cell 1 Voltage Low Byte (Low Pass Filtered))
209	80	VCELL2_HF Description: Cell 3 Voltage High Byte (Low Pass Filtered))
20A	00	VCELL2_LF Description: Cell 2 Voltage Low Byte (Low Pass Filtered))
20B	80	VCELL3_HF Description: Cell 3 Voltage High Byte (Low Pass Filtered))
20C	00	VCELL3_LF Description: Cell 3 Voltage Low Byte (Low Pass Filtered))
20D	80	VCELL4_HF Description: Cell 4 Voltage High Byte (Low Pass Filtered))
20E	00	VCELL4_LF Description: Cell 4 Voltage Low Byte (Low Pass Filtered))
20F	80	VCELL5_HF Description: Cell 5 Voltage High Byte (Low Pass Filtered))
210	00	VCELL5_LF Description: Cell 5 Voltage Low Byte (Low Pass Filtered))
211	80	VCELL6_HF Description: Cell 6 Voltage High Byte (Low Pass Filtered))
212	00	VCELL6_LF Description: Cell 6 Voltage Low Byte (Low Pass Filtered))
213	00	CONV_CNTH Description: Cell ADC Conversion Counter High Byte)
214	00	CONV_CNTL Description: Cell ADC Conversion Counter Low Byte)
215	80	VCELL1H Description: Cell 1 Voltage High Byte (Corrected))
216	00	VCELL1L Description: Cell 1 Voltage Low Byte (Corrected))
217	80	VCELL2H Description: Cell 3 Voltage High Byte (Corrected))
218	00	VCELL2L Description: Cell 2 Voltage Low Byte (Corrected))
219	80	VCELL3H Description: Cell 3 Voltage High Byte (Corrected))
21A	00	VCELL3L Description: Cell 3 Voltage Low Byte (Corrected))
21B	80	VCELL4H Description: Cell 4 Voltage High Byte (Corrected))
21C	00	VCELL4L Description: Cell 4 Voltage Low Byte (Corrected))
21D	80	VCELL5H Description: Cell 5 Voltage High Byte (Corrected))
21E	00	VCELL5L Description: Cell 5 Voltage Low Byte (Corrected))
21F	80	VCELL6H Description: Cell 6 Voltage High Byte (Corrected))
220	00	VCELL6L Description: Cell 6 Voltage Low Byte (Corrected))
221	80	VCELL_FACTCORRH Description: Selected Cell Factory Corrected High Byte)
222	00	VCELL_FACTCORRL Description: Selected Cell Factory Corrected Low Byte)
223	80	AUX_CELLH Description: AUX Cell Measurement Voltage Low Byte)
224	00	AUX_CELLL Description: AUX Cell Measurement Voltage Low Byte)
225	80	AUX_BATH Description: Cell Stack Voltage High (Corrected))
226	00	AUX_BATL Description: Cell Stack Voltage Low (Corrected))
227	80	AUX_REF2H Description: Bandgap 1 Voltage Output High Byte)
228	00	AUX_REF2L Description: Bandgap 1 Voltage Output Low Byte)
229	80	AUX_ZEROH Description: ZERO Reference Voltage High Byte)
22A	00	AUX_ZEROL Description: ZERO Reference Voltage Low Byte)
22B	80	AUX_AVDDH Description: AVDD LDO Voltage Output)
22C	00	AUX_AVDDL Description: AVDD LDO Voltage Output Low Byte)
22D	80	AUX_GPIO1H Description: GPIO1 Voltage High (Corrected))
22E	00	AUX_GPIO1L Description: GPIO1 Voltage Low (Corrected))
22F	80	AUX_GPIO2H Description: GPIO2 Voltage High (Corrected))
230	00	AUX_GPIO2L Description: GPIO2 Voltage Low (Corrected))
231	80	AUX_GPIO3H Description: GPIO3 Voltage High (Corrected))
232	00	AUX_GPIO3L Description: GPIO3 Voltage Low (Corrected))
233	80	AUX_GPIO4H Description: GPIO4 Voltage High (Corrected))
234	00	AUX_GPIO4L Description: GPIO4 Voltage Low (Corrected))
235	80	AUX_GPIO5H Description: GPIO5 Voltage High (Corrected))
236	00	AUX_GPIO5L Description: GPIO5 Voltage Low (Corrected))
237	80	AUX_GPIO6H Description: GPIO6 Voltage High (Corrected))
238	00	AUX_GPIO6L Description: GPIO6 Voltage Low (Corrected))
239	80	AUX_FACTCORRH Description: Selected GPIO Factory Corrected High Byte)
23A	00	AUX_FACTCORRL Description: Selected GPIO Factory Corrected Low Byte)
23B	80	DIE_TEMPH Description: Die Junction Temperature High Byte)
23C	00	DIE_TEMPL Description: Die Junction Temperature Low Byte)
23D	80	AUX_REF3H Description: Bandgap 2 Voltage Output High Byte)
23E	00	AUX_REF3L Description: Bandgap 2 Voltage Output Low Byte)
23F	80	AUX_OV_DACH Description: OV Reference Voltage High Byte)
240	00	AUX_OV_DACL Description: OV Reference Voltage Low Byte)
241	80	AUX_UV_DACH Description: UV Reference Voltage High Byte)
242	00	AUX_UV_DACL Description: UV Reference Voltage Low Byte)
243	80	AUX_OT_DACH Description: OT Reference Voltage High Byte)
244	00	AUX_OT_DACL Description: OT Reference Voltage Low Byte)
245	80	AUX_UT_DACH Description: UT Reference Voltage High Byte)
246	00	AUX_UT_DACL Description: UT Reference Voltage Low Byte)
247	80	AUX_TWARN_PTATH Description: TWARN PTAT Current High Byte)
248	00	AUX_TWARN_PTATL Description: TWARN PTAT Current Low Byte)
249	80	AUX_DVDDH Description: DVDD LDO Voltage Output High Byte)
24A	00	AUX_DVDDL Description: DVDD LDO Voltage Output Low Byte)
24B	80	AUX_TSREFH Description: TSREF Voltage Output High Byte)
24C	00	AUX_TSREFL Description: TSREF Voltage Output Low Byte)
24D	80	AUX_CVDDH Description: CVDD LDO Voltage Output High Byte)
24E	00	AUX_CVDDL Description: CVDD LDO Voltage Output Low Byte)
24F	80	AUX_AVAOH Description: AVAO Reference Voltage High Byte)
250	00	AUX_AVAOL Description: AVAO Reference Voltage Low Byte)
260	00	SPI_RX Description: SPI Byte Read)
261	3F	CB_DONE Description: Cell Balancing Complete Status)
262	00	GPIO_STAT Description: GPIO Input Status)
263	00	CBVC_COMP_STAT Description: CBVC Comparator Status)
264	00	CBVC_VCLOW_STAT Description: CBVC VCLOW Comparator Status)
265	00	COMM_UART_RC_STAT3 Description: Discarded UART Command Frame Counter)
266	00	COMM_COML_RC_STAT3 Description: Discarded COML Command Frame Counter)
267	00	COMM_COMH_RR_STAT3 Description: Discarded COMH Response Frame Counter)
268	00	COMM_COML_RR_STAT3 Description: Discarded COML Response Frame Counter)
269	00	COMM_COMH_RC_STAT3 Description: Discarded COMH Command Frame Counter)
26A	00	COMM_UART_RR_STAT3 Description: Discarded UART Response Frame Counter)
26B	00	COMM_UART_RC_STAT1 Description: Valid UART Command Frame Counter High Byte)
26C	2D	COMM_UART_RC_STAT2 Description: Valid UART Command Frame Counter Low Byte)
26D	00	COMM_COML_RC_STAT1 Description: Valid COML Command Frame Counter High Byte)
26E	00	COMM_COML_RC_STAT2 Description: Valid COML Command Frame Counter Low Byte)
26F	00	COMM_COMH_RR_STAT1 Description: Valid COMH Response Frame Counter High Byte)
270	00	COMM_COMH_RR_STAT2 Description: Valid COMH Response Frame Counter Low Byte)
271	00	COMM_UART_TR_STAT1 Description: Transmitted UART Response Frame Counter High Byte)
272	1E	COMM_UART_TR_STAT2 Description: Transmitted UART Response Frame Counter Low Byte)
273	00	COMM_COML_TR_STAT1 Description: Transmitted COML Response Frame Counter High Byte)
274	00	COMM_COML_TR_STAT2 Description: Transmitted COML Response Frame Counter Low Byte)
275	00	COMM_COMH_RC_STAT1 Description: Valid COMH Command Frame Counter High Byte)
276	00	COMM_COMH_RC_STAT2 Description: Valid COMH Command Frame Counter Low Byte)
277	00	COMM_COML_RR_STAT1 Description: Valid COML Response Frame Counter High Byte)
278	00	COMM_COML_RR_STAT2 Description: Valid COML Response Frame Counter Low Byte)
279	00	COMM_COMH_TR_STAT1 Description: Transmitted COMH Response Frame Counter High Byte)
27A	00	COMM_COMH_TR_STAT2 Description: Transmitted COMH Response Frame Counter Low Byte)
27B	00	COMM_UART_RR_STAT1 Description: Valid UART Response Frame Counter High Byte)
27C	00	COMM_UART_RR_STAT2 Description: Valid UART Response Frame Counter Low Byte)
27D	00	OTP_PROG_STAT Description: OTP Programming Status)
27E	01	OTP_CUST1_STAT1 Description: Customer OTP Page 1 Status)
27F	00	OTP_CUST1_STAT2 Description: Customer OTP Page 1 Programming Status)
280	01	OTP_CUST2_STAT1 Description: Customer OTP Page 2 Status)
281	00	OTP_CUST2_STAT2 Description: Customer OTP Page 2 Programming Status)
282	00	CB_SW_STAT Description: Cell Balancing Switch Status)
290	00	GPIO_FAULT Description: GPIO Fault  Status)
291	00	UV_FAULT Description: UV Comparator Fault Status)
292	00	OV_FAULT Description: OV Comparator Fault Status)
293	00	UT_FAULT Description: UT Comparator Fault Status)
294	00	OT_FAULT Description: OT Comparator Fault Status)
295	00	TONE_FAULT Description: FAULT Bus Status)
296	05	COMM_UART_FAULT Description: UART Fault Status)
297	00	COMM_UART_RC_FAULT Description: UART Receive Command Fault Status)
298	00	COMM_UART_RR_FAULT Description: UART Receive Response Fault Status (only valid in multidrop mode))
299	00	COMM_UART_TR_FAULT Description: UART Transmit Fault Status)
29A	00	COMM_COMH_FAULT Description: COMH Fault Status)
29B	00	COMM_COMH_RC_FAULT Description: COMH Receive Command Fault Status)
29C	00	COMM_COMH_RR_FAULT Description: COMH Receive Response Fault Status)
29D	00	COMM_COMH_TR_FAULT Description: COMH Transmit Fault Status)
29E	00	COMM_COML_FAULT Description: COML Fault Status)
29F	00	COMM_COML_RC_FAULT Description: COML Receive Command Fault Status)
2A0	00	COMM_COML_RR_FAULT Description: COML Receive Response Fault Status)
2A1	00	COMM_COML_TR_FAULT Description: COML Transmit Fault Status)
2A2	00	OTP_FAULT Description: OTP Page Fault Status)
2A3	00	RAIL_FAULT Description: Power Rail Fault Status)
2A4	00	OVUV_BIST_FAULT Description: OTUT BIST Fault Status)
2A5	00	OTUT_BIST_FAULT Description: OTUT BIST Fault Status)
2B0	00	ECC_DATAOUT0 Description: 1st Data Out Byte for ECC Test)
2B1	00	ECC_DATAOUT1 Description: 2nd Data Out Byte for ECC Test)
2B2	00	ECC_DATAOUT2 Description: 3rd Data Out Byte for ECC Test)
2B3	00	ECC_DATAOUT3 Description: 4th Data Out Byte for ECC Test)
2B4	00	ECC_DATAOUT4 Description: 5th Data Out Byte for ECC Test)
2B5	00	ECC_DATAOUT5 Description: 6th Data Out Byte for ECC Test)
2B6	00	ECC_DATAOUT6 Description: 7th Data Out Byte for ECC Test)
2B7	00	ECC_DATAOUT7 Description: 8th Data Out Byte for ECC Test)
2B8	00	ECC_DATAOUT8 Description: 9th Data Out Byte for ECC Test)
2B9	00	SEC_BLK Description: SEC Detected Block)
2BA	00	DED_BLK Description: DED Detected Block)
2BB	00	DEV_ADD_STAT Description: Device Address Status)
2BC	03	COMM_STAT Description: Communication Status Register)
2BD	13	DAISY_CHAIN_STAT Description: Communication Status Register)
2C0	80	VCELL1_HU Description: Cell 1 Voltage High Byte (Uncorrected))
2C1	00	VCELL1_MU Description: Cell 1 Voltage Middle Byte (Uncorrected))
2C2	00	VCELL1_LU Description: Cell 1 Voltage Low Byte (Uncorrected))
2C3	80	VCELL2_HU Description: Cell 3 Voltage High Byte (Uncorrected))
2C4	00	VCELL2_MU Description: Cell 2 Voltage Middle Byte (Uncorrected))
2C5	00	VCELL2_LU Description: Cell 2 Voltage Low Byte (Uncorrected))
2C6	80	VCELL3_HU Description: Cell 3 Voltage High Byte (Uncorrected))
2C7	00	VCELL3_MU Description: Cell 3 Voltage Middle Byte (Uncorrected))
2C8	00	VCELL3_LU Description: Cell 3 Voltage Low Byte (Uncorrected))
2C9	80	VCELL4_HU Description: Cell 4 Voltage High Byte(Uncorrected))
2CA	00	VCELL4_MU Description: Cell 4 Voltage Middle Byte (Uncorrected))
2CB	00	VCELL4_LU Description: Cell 4 Voltage Low Byte (Uncorrected))
2CC	80	VCELL5_HU Description: Cell 5 Voltage High (Uncorrected))
2CD	00	VCELL5_MU Description: Cell 5 Voltage Middle Byte (Uncorrected))
2CE	00	VCELL5_LU Description: Cell 5 Voltage Low Byte (Uncorrected))
2CF	80	VCELL6_HU Description: Cell 6 Voltage High Byte(Uncorrected))
2D0	00	VCELL6_MU Description: Cell 6 Voltage Middle Byte (Uncorrected))
2D1	00	VCELL6_LU Description: Cell 6 Voltage Low Byte(Uncorrected))
2D2	80	AUX_BAT_HU Description: Cell Stack Voltage High (Uncorrected))
2D3	00	AUX_BAT_LU Description: Cell Stack Voltage Low(Uncorrected))
2D4	80	AUX_GPIO1_HU Description: GPIO1 Voltage High (Uncorrected))
2D5	00	AUX_GPIO1_MU Description: GPIO1 Voltage Middle Byte (Uncorrected))
2D6	00	AUX_GPIO1_LU Description: GPIO1 Voltage Low (Uncorrected))
2D7	80	AUX_GPIO2_HU Description: GPIO2 Voltage High (Uncorrected))
2D8	00	AUX_GPIO2_LU Description: GPIO2 Voltage Low (Uncorrected))
2D9	80	AUX_GPIO3_HU Description: GPIO3 Voltage High (Uncorrected))
2DA	00	AUX_GPIO3_LU Description: GPIO3 Voltage Low (Uncorrected))
2DB	80	AUX_GPIO4_HU Description: GPIO4 Voltage High (Uncorrected))
2DC	00	AUX_GPIO4_LU Description: GPIO4 Voltage Low (Uncorrected))
2DD	80	AUX_GPIO5_HU Description: GPIO5 Voltage High (Uncorrected))
2DE	00	AUX_GPIO5_LU Description: GPIO5 Voltage Low (Uncorrected))
2DF	80	AUX_GPIO6_HU Description: GPIO6 Voltage High (Uncorrected))
2E0	00	AUX_GPIO6_LU Description: GPIO6 Voltage Low Byte (Uncorrected))
2E1	91	CUST_CRC_RSLTH Description: Calculated Customer CRC Result High Byte)
2E2	71	CUST_CRC_RSLTL Description: Calculated Customer CRC Result Low Byte)
    The cell balancing timers and CB_DONE_THRESH run in parallel and either can signal done to the comparator. From the register settings printout it seems that the cell balancing timer is set to only 1 minute. This indicates to me that the system is likely hitting the 1 minute timer prior to reaching the threshold of 2.8V. To prove this, please up the CB_CELLX_CTRL and see if the issue goes away.
    This parallelization of the procedures is best seen in Figure 19 under section 8.3.5.1.3 of the datasheet.
    Geoff Grimmer
