Hi Team,
The TPS22933 uses 3 P channel MOSFETs as high side switches and their gates are controlled by the control logic based on which among the input voltage is high.
The body diode of all the MOSFETs are forward biased when voltage is supplied at their corresponding input pins.
If that is the case, it will be just a diode ORing. Right?.
