Other Parts Discussed in Thread: TPS63802
I am trying to design the simplest schematic for the LM2621 in a SEPIC configuration to run off of 3x 1.5v batteries. I need a fixed 3.3v out. The batteries will start at 4.5v and I want to run as low as possible (down to 1.2v hopefully). It seems the datasheet SEPIC design can only run down to 2.5v and I need to run with a lower VIN than that. I have seen other schematics from other sources but would like to have a recommended solution from a TI expert with the simplest schematic possible (other solutions accommodate higher VIN or VOUT which I believe complicates the design). Is there a known/recommended design that matches these parameters? (VIN=1.2v-4.5v, VOUT=3.3v). Thanks.
