Hi experts,
For TPS7B7702-Q1, do you have a curve of RθJA vs. copper area like below?
For VIN=16, VOUT=8V, IOUT1=0.2A, IOUT2=0.2A, the total power dissipation will be 3.2W, if using RθJA=40.3C/W in datasheet, TA=75C, the calculated TJ will exceed the max operating TJ 150C. So can TPS7B7702-Q1 support this application? Is it necessary to add heat-sink? Thank you.
Arie
