Hi, TI expert.
A customer has an inquiry about the Fall time of SCL signal of I2C Interface of TPS65235.
If you look at the datasheet, the MIN spec is 20ns.
However, if you actually measure it, it is measured as 12.859ns. (see SCL CLK waveform below)
If the measured value is less than the spec of 20ns, is there a problem in operation?
What are the problems?
Please check. Thank you.
Hi, Grady
There is no problem when fall time of SCL and CLK is smaller than 20nS.
