Part Number: BQ25155EVM
Other Parts Discussed in Thread: BQ25155
I have questions about some watchdog defined for the device BQ25155.
- In the chapter 8.3.2.2 Safety Timer and I 2C Watchdog Timer of the document bq25155.pdf, this is reported:
Can you kindly indicated which is the I2C register where the watchdog can be enabled-disabled ?
2. Does tWATCHDOG_SW refer to the above mentioned watchdog ? Can you explain the significant range 25 -50 seconds ?
Thanks in advance for your kind support.
BR
Riccardo Gaiati
