Other Parts Discussed in Thread: TPS53319, TPS53318, TPS53355
Hi
The following TPS53353 current limit formula, why is there a difference between 12.1A and 16A?
TPS53318_TPS53319_TPS53353_TPS53355_Calculator_Checklist_2021Jan19.xlsx
Hi
The main difference in the above calculations is that the excel document uses a thermally compensated RDS(on) value of 1.6mohm in its calculation of the current limit. I would use the excel tool as the more authoritative source in your design.
Please see the attached segment in section 8.2.1.1 for a design example where the thermally compensated RDS(on) value is employed:
Alec Biesterfeld
