Other Parts Discussed in Thread: LM2941
I’m developing a LM25011A low-drop-out-voltage step-down converter.
However, this question is about protecting the LM25011A from destruction during development – rather than how to get low-drop-out (If I need to – I’ll ask about that later).
I appear to have destroyed about 5 of these ICs. My latest effort has the LM25011A current limiting the bench power supply and being to hot to touch. Possibly the internal Mosfet is destroyed.
I’m pondering whether the Mosfet has been damaged by excessive current to 0V? Unlikely in my circuit.
Or is it back EMF? On the 7.2 Functional block Diagram – it doesn’t show a Mosfet diode.
I’m trying different inductors and normal converter operation stops happening. I find that it pulses the inductor at a slower frequency (maybe at - 0.2A 0.62 ohm - Current Limit frequencies).
Under proper operation, the SW node has shortish pulses towards ground.
Possibly once the IC is destroyed, I get an inversion of that - with low level having high level pulses.
Should I put a reverse Schottky diode between Vin and SW?
Is there any other typical reason why these ICs get destroyed? I noticed other customers comments on these ICs failing.
Peter
