Part Number: TPS552882
Hi
I have recently been designing a new dc-dc power supply using the TI TPS552882RPMR. I have been using the Webench Power Designer application on the website which is good. However I have noticed a problem when moving from the Customize tab to the Export tab and vice versa. What seems to happen is the initial generated schematic is altered where a connection is added to the Feedback net and Vout and effectively shorting the Rfbt resistor. This I assume is bug in the application so I have continued to make my design without this connection.
However, I would like for someone to confirm this is indeed a slight mistake that has been identified before I complete my PCB design.
I have included an image to show the issue. Hope this helps.
Many Thanks
Dave
