Other Parts Discussed in Thread: LM2642, TPS51220
I note that the TPS51222 has two outputs with 180 degrees of phase difference. I wonder if we can combine the two outputs together to generate a larger current output. I failed to find the description in the datasheet.
By the way, I am using LM2642 which can combine two outputs together to generate a single output with larger current. I want to evalute TPS51222 which has smaller footprint.
Frank
