Other Parts Discussed in Thread: TPS62160, TPS62125
For the TPS62170 (and also the TPS62160) , the vout max is listed as 6V. What is driving this limitation? Is there a work-around to get 9V output (with say, 12V input)?
The device is similar to the TPS62125 which has a higher output rating (up to 10V). We are looking for a pin compatible replacement to that device due to supply constraints.
