Hi could I please get detailed instructions for the current scaling bug work around? I have been waiting for updated firmware to resolve the issue but with no solution in 10 months and no indication of a firmware release date, it would be good to get a bit more info on what to do.
For example this post says to calibrate 50A as 25A and adjust all capacities by a factor of 2:
Could you at least specify all of the parameters which need to be adjusted by a factor of 2?
Do all the current protections and smart charge algorithm current values etc also need to be adjusted?
Should current scaling factor still be used in conjunction with this work around?
