BQ25155: Interrupt generation in the transition Low Power <-> Charger/Adapter Mode
Part Number: BQ25155
  • The device stands in low power (so interrupts disabled). Then it exits this state because VIN becomes greater than VUVLO and enters in Charger mode.
Will the interrupt VIN_PGOOD be generated in this transition ?
  • Viceversa, the device stands in Charger mode, VIN is removed and low power is entered.
I am trying to see if there is an alternative to the usage of the PG pin (which we need to output the /MR signal).
Thanks in advance !
