The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
BQ24278: RGE0024H footprint?
Part Number: BQ24278
Other Parts Discussed in Thread: TCA9548A,
Good evening.....
I keep my library parts in a local database and like to re-use footprints where possible.  I have a TCA9548A part that uses a RGE0024C.  I notice that this is the same footprint as the BQ24278 part that I want to use except for the suffix H instead of C.  Is the H just a newer re-vision over time from TI or is it an all together different part number?  The only difference I can see is the size of the center pad (ground).
  • Hi Steve,
    Since these parts released within a month of each in 2012, H version is not later revision but is a different package with larger heatsink pad.  I predict that the C footprint can accommodate the H device.
    regards,
    Jeff
