Hi Team,
We use the TPS3808G33DBV to do voltage monitoring for TMS570 MCU.
I am confusing about the R5 pull resistor value selection. I am referring to TPS3808G33 datasheet, R5 should keep above 10Kohm.
And below the the requirement for nPORRST from TMS570 MCU datasheet.
because R5 must be higher than 10k, so the high level output Vreset_n=3.3V-100uA*10k=2.3V . It is too low for electrical level.
I want to change R5 to 4.7K, so Vreset_n=3.3V-100uA*4.7k=2.83V , it's tolerance become better.
But in the reference of TPS3808, i am confused about no smaller than 10k.
Could you please give some guide for the R5 value setting? Thanks.
