TPS61161-Q1: CTRL and VIN sequence at power up
Part Number: TPS61161-Q1
Hi Ti E2E,
Due to TPS61161-Q1 has a soft start built-in IC, the Vout at SW may have two step ramp up behavior at system power up.
I am wondering if there is any risk for give PWM signal to CTRL pin first then turning power rail to power up VIN to eliminating 2 steps ramping up behavior.
Or if there is any other work around solution for eliminating 2 steps Vout behavior?
Thanks for your kindly help!
Jack Chang
