Hi, team,
For LM5020, is there a plot for maximum duty cycle vs. frequency? Thanks!
Hi, team,
Hi Nicole,
There is unfortunately no current plot for maximum duty cycle vs frequency. If you need to check, start input voltage to be high enough to hit regulation target; and then probe OUT pin while lowering input voltage. Eventually, you will find where IC will fall out of regulation, which means you have hit maximum duty cycle.
Richard
