Other Parts Discussed in Thread: TPS57114-Q1, TPS57114C-Q1,
Does this EP part incorporate the change that was made to TPS57114-Q1 to become TPS57114C-Q1? If not will TI be doing that soon?
Hi David,
Let me check on this.
Do you need an -EP device for your application or just something that operates down to -55C or something else special?
Chris
Hi David,
The -EP device will not undergo the same change as the -Q1 device since the package design of the -EP device already provides a higher robustness level than the original TPS57114-Q1 device before the PCN. If there was a similar change done on the TPS57114-EP, you should receive a PCN notification just like customers did for the TPS57114-Q1 change.
Chris
