Hi Expert,
Below is the questions will need your comment to clarify.
There are tdVdT = 20.8 × 103 × V(IN) × C(dVdT) in the equation 1.
1)May we know why 20.8 is used here?
2) If we fixed the CdVdT (from same cap on the dVdT pin) in the design with same Vin now. Since the slew rate is fixed now. Whether lower or higher the out capacitance in this case, the output rising time should the same as well?
Eric Lai
Field Application Engineer
Texas Instruments Taiwan Limited
O: +886-2-2175-2582
M: +886-909-262-582
E-Mail:Eric.Lai @ti.com
