BQ25618: The standby current of BQ25618
Part Number: BQ25618
Hi Team,
Do you know the standby current? If want to test the standby by current of BQ25618, whether need set the Vbus as no input and charging as no charging? I have checked the datasheet and it doesn't obtain the standby current of BQ25618. It only obtains the 9.5uA low battery leakage current with system standby. Is it the standby current? How to test it?
Gust
  • Gust,
    The "QUIESCENT CURRENTS" section in 7.6 Electrical Characteristics should be what you are looking for. The "test conditions" column describes the test conditions for measuring the corresponding parameter.
    Ning.
