TLV702-Q1: Help to check D/C from Top marking and Label?
Part Number: TLV702-Q1
Pls help to check if date code on chip surface is consistent with Date Code on the label.
Should the dot on the right be the first dot or the second dot? It's a little confused.
Pls help to figure out and advise ASAP.  Thanks in advance for your time.
