TPS65253: documentation discrepancies in datasheet and EVM user's guide
Part Number: TPS65253
1. I came across this forum post that covers one of my questions with regard to the pin nomenclature in the EVM user's guide. Any idea of when the EVM document will be updated?
https://e2e.ti.com/support/power-management-group/power-management---internal/f/power-management---internal-forum/508219/tps65253---evm-schematic-does-not-match-data-sheet?tisearch=e2e-sitesearch&keymatch=tps65253#
Additional items:
2. The current limit calculations do not seem to match exactly what is in the datasheet and EVM user's guide. Both formulas have a fixed difference, but I will use one of them as an example. ILIM1 = 252/Rlim+0.6. If using the value of 59kΩ from the datasheet, the result is 4.87A, and not 5A.
3. Capacitor C5 on datasheet page 3 should be 10uF and not 10nF. Can you please confirm?
4. Should "pin 229"page 17 be "pin 22"?
5. If you revise the spec, please fix the typo in the first page, under features "Eenable".
Thank you!
