Hello Team,
Could you please help to answer the comments and questions below:
I have a new RF amp design where I would like to use the LP38798. Per the datasheet, I noticed that the part uses a charge pump at ~3.5MHz. LDOs with a charge pump generally exhibit some kind of low level output spur related to that charge pump. I looked in the datasheet and on the web-based forum and did not see mention of the spur and/or its level. So, my question is:
Q). What is the anticipated output level of the spur from the 3.5MHz charge pump?
Dajon McGill
