Hello support team,
My customer inquires TPS2490 power limit behavior, could you support?
*Datasheet shows "If the constant power limit is not used, PROG should be tied to VREF through a 47-kΩ resistor.". When PROG pulled up to VREF, in other word, power limit is disabled, can current limit work? Or no protection work, if PROG pulled high?
*Can user set enable / disable power limit on-the-fly? E.g. after start up with power limit, can user disable power limit?
Koji Ikeda
