Other Parts Discussed in Thread: LMZ14203H
I need to develop a variable output power supply module capable of supplying a 5-24 volt output voltage at 5-1000mA. In experimenting with the LMZ14201H module in the WEBENCH tool, I struggled to find a set of resistor values that would work across the full range of current and voltages I need. Is this goal achievable with this part? If not, can you suggest a more appropriate part.
