Hello all,
I intend to use the BQ24104 to charge a lithium ion battery pack- but the battery pack I am sourcing does not have a thermistor output. The internal battery management circuit inside of the pack does have temperature safety shutoffs, so safety-wise I'm not too concerned, but for this charging application I cannot use the TS pin to monitor temperatures.
What resistor values should I put onto the TS pin to have it not interrupt charging at all?
I am charging an 8.4V battery at 2A with a 12V source.
Thank you!
