Other Parts Discussed in Thread: UCC27201A
Hi Support team
pls kindly check UCC27201A-Q1 Input threshold is CMOS or TTL ?
I assume it's same as UCC27201A, TTL, but following shows CMOS
Hi Support team
Thank you for your question. It is the same as UCC27201A, TTL logic. For specific input voltage high, and input voltage low thresholds, you can refer to the VHIT and VLIT parameters in the Electrical Characteristics table in the device datasheet.
Leslie
Hi Leslie,
thanks for your answer, before your close the status, are you able to verify it on TI homepage,
due to this parameter confuse my customer a lot
thanks a lot
Red Yen
Hi Red,
We did identified a few day ago that the product description mentions "CMOS input threshold" on ti.com. We are working with our digital marketing team to fix this. It should say "TTL input threshold".
Thanks for bringing this to our attention!
Leslie
