Other Parts Discussed in Thread: TPS54202
Hi team,
My customer has questions about the datasheet description. Please help me.
Q1. According to the TPS563200 datasheet, EN threshold is described as "EN high-level input voltage, min 1.6V", does it mean the IC can be enabled V_EN=1.6V or above considering variation range?
Q2. On the TPS54202 datasheet, EN threshold is described as "Rising: Typ. 1.21V, Max. 1.28V", does it mean some IC can be enabled at V_EN=1.28V due to the variation?
Q3. The difference of description between TPS563200 and TPS54202 means these have different structure for EN? otherwise it is just a writing difference?
TPS563200
TPS54202
Kazuto
