UC1707: 5962-8761901EA and UC1707J883B difference
Part Number: UC1707
Hi Team,
May I ask for your confirmation? I check datasheet of UC1707 to verify the difference between 5962-8761901EA and UC1707J883B.
Yet, I was not able to find its differences. Can you please help me with this? I need to know differences in electrical characteristics if there is any.
I also check FAQ involving DLA SMD part number and notice that the 5962-8761901EA does not indicate what QML class it belongs. As additional concern what does "blank" QML class in part number mean?
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/995648/faq-i-need-help-interpreting-or-finding-smd-part-numbers-for-ti-military-and-space-grade-devices
I hope you can help me with this.
Thank you so much and kind regards,
Gerald
  • Hi Gerold,
    Thanks for reaching out!
    Under the UC1707 product folder, you will see the standard device.
    Under the UC1707-SP product folder, you will see the space-grade part that has a QML rating.
    (5962-8761901VEA)
    The parts should be electrically the same if they have the same part number and the datasheet does not say otherwise either.
    I hope this helps clears things up!  If I answered your question, please press the green button; otherwise, feel free to follow up!
    Aaron Grgurich
